Enjoy the video on your iphone
Micky1020
on Jun 29, 2007 at 8:50:40 am
Enjoy YouTube Video and Google Video on your iPhone with FLV to Video Converter
This tutorial is to show you the solution to convert FLV to iPhone movie with Moyea FLV to Video Converter Pro
Apple iPhone is the revolutionary new mobile phone that allows you to make a call by simply tapping a name or number in your address book, a favorites list, or a call log. The Apple iPhone will double as both a cell phone and iPod allowing you to store music from your iTunes library on your iPhone.
FLV, or Flash video, is the proprietary file format for delivering video files on the Internet, and it is widely applied today. Here is the solution to turn your favorite FLV to iPhone movie to enjoy on the go, in private or with your friends.
Moyea FLV to Video Converter is a choice FLV to iPhone conversion program to convert Flash video (FLV) to iPhone movie with high image and sound quality. Meanwhile this iPhone movie converter supports batch conversion mode.
Launch Moyea FLV to Video Converter
Note: This program is based on the batch conversion mode. If you have added multiple FLV files into the program, these files will be converted according to your settings one by one.
Set the parameters of the Flash video
Once the target FLV file is imported into the program, you can click on the Settings tab to adjust the audio and video settings to fit the iPhone playback
You can select MP4 as the output file format, and iPhone as the sub-type. For iPhone movie, the program has preset the frame size of 480*320 pixels. Besides, you are availed to set the frame rate, bit rate, channels, etc for the output iPhone video.
Convert
Once you have set the relevant parameters for the output iPhone video, you can click on the Convert tab to start encoding the desired video.
Moyea FLV to Video Converter is easy to use and efficient. With this program, converting your favorite FLV files to the video for playback on iPhone is within a few clicks.
Now, Moyea offers the free trial version of the FLV to video conversion program on its website, have a try, and enjoy it!
[URL=http://www.flvsoft.com]Download
