X1900XTX display corruption
Bruce Argue
on Apr 26, 2007 at 10:10:47 am
I've just installed an X1900XTX. Since doing so, I have a display corruption. Here's a screen dump showing the problem:
In program windows, they also appear and leave pink trails if you move the window. I've tried the latest driver and e-installed Catalyst Control Centre but no change. The problem disappears if I change to 16-bit colour as opposed to 32-bit
The display looked fine in 32-bit colour with the old X1300 and also with a Matrox 450.
This is my system spec:
MSI 975X Platinum Power Up
E6600 proc
2Gb RAM
250Gb Maxtor SATA system disk
2 x 500Gb Seagate Barracuda SATA disks (will be configured as RAID 0 once I figure out how to load Jmicrontools as CTRL+J doesn't seem to do it)
Card reader
2 x DVD drives
650w Atrix PSU
Windows XP Pro
Is there anything else to try or is the card faulty?
elpjg
Re: X1900XTX display corruption
on Jun 4, 2007 at 1:53:06 pm
Go at Avid forum : there are many post on this subject - not funny Crying or Very sad
Bruce Argue
on Jun 4, 2007 at 4:24:58 pm
Thanks fo ryour input. By Avid forum do you mean Video Editing Software on here? I don't use Avid and the problem appears before I load Premier. Can you be more specific? Anyhow, haved RMAed the card so will see what that turns up.
