How to Convert DVD to iPod/Zune/iPhone/PSP/ PS3/Youtube/Xbox
mrrobben720
on Apr 23, 2007 at 9:03:23 am
This step-by-step user guide is about how to use Wondershare DVD Ripper Platinum to rip your DVD for iPod, Zune, iPhone, PSP, Apple TV, Creative Zen, Xbox, iRiver, Archos, Dell player video, HP IPAQ, Pocket PC, Mobile Phone, General MP3 player and so on
Now let’s get started.
Download Wondershare DVD Ripper Platinum (latest version: 3.0.16) and install the program on your computer. [url=http://download.dvd-ripper-copy.com/drp_trial.exe]Download Here [url=http://www.dvd-ripper-copy.com/dvd-ripper-platinum.html]Learn more
1.Load the file
You can load your DVD by any of the three methods: load from DVD folder, load DVD Rom and load IFO Files. The default choice is to load from DVD folder. Click the Load file icon to load your movie from DVD folder, or click the small arrow next to this icon to select a method to load your movie.
2.Select subtitle, audio track and output format
a) Regular DVD movie usually has several subtitles, like English, French, German, etc. You can select anyone according to your need.
b) Select Audio track as the same as select Subtitle.
c) Format: this software can convert DVD to all popular formats, it also can extract audio track from DVD and save as MP3 and M4A formats which are fit for digital audio players.
3.Start conversion
If you don’t want to set any detailed settings, you can just select an output format from the format drop-down list and click the “Start” button to start the conversion. Then you can just go get a cup of coffee and come back later to check if the conversion is finished.
However, before you start the conversion, you may find the following operations to be very useful:
Trim movie: If you don’t need to convert the entire DVD movie, you can just capture a clip from it to convert. See the two pairs of scissors under the Preview window? The scissors one the left are used to set the start time, and the scissors on the right are used to set the end time. Drag them to capture the clip you want to convert. If you want to precisely trim the video, you can click the Trim button on the top of the preview window.
Crop Video: There are always black edges around DVD movies; you can easily remove them with this DVD Ripper. Click the Edit icon to open the Edit window.
Go to the Crop tab, and you can set the output video aspect ratio crop the movie video. The program provides you with three methods to crop your video: select a crop mode from the Crop down-down menu, drag the crop frame around your video, or set the crop values (Up, Down, Left and right).
If you want to change the video effects, you can go to the Effect tab to set the brightness, contrast, saturation and select a pre-set movie effect.
Tips:
A Higher bit rate and frame rate provide result in better quality with larger size but larger output file.
B You can merge several chapters into one file by ticking the box “merge into one file”
C If you like the current picture in the Preview window, you can capture and save it by clicking the “snapshot” button.
D You can set the image output directory and the image type of the captured pictures in the option window.
E This DVD Ripper supports a wide range of video formats that can be played on iPod, Apple TV, iPhone, PSP, Creative Zen, Xbox, iRiver, Archos, Dell player video, HP IPAQ, Pocket PC, Mobile Phone, General MP3 player and so on.
May this guide helps, if you have any questions, you can PM me, I will reply A.S.A.P.
