need to convert Adobe Premiere Pro file into flash file
mervyn
on Mar 16, 2007 at 4:10:31 pm
Hi how is this done only I keep getting an error when i go through the export method and the adobe media encoder method. any help would be great.
Regards Mervyn.
I am on PAL setup
ClearVision Studios
Re: need to convert Adobe Premiere Pro file into flash file
on Apr 6, 2007 at 12:19:41 am
Do you have After Effects?
Premiere doesn't seem to do a good job of converting to Flash yet but AE has no problems doing it.
mervyn
re:converting to flash
on Apr 6, 2007 at 6:20:22 am
Hi many thanks for your reply' yes I do have AE I did not think of trying this so I will look into it and give it a go.
Regards Mervyn
strait
on Apr 6, 2007 at 11:25:58 am
here is my suggestion:
1. export your work in Premiere as video file
2. convert video file to flash using [url=http://www.visifly.com/VisFly/]VisiFly
ClearVision Studios
on Apr 6, 2007 at 3:32:53 pm
Your welcome. I have had the best luck with exporting the video as an AVI from premiere and then just import it in to AE, then drop it on a timeline and export your FLV. Good luck.
