Power keeps shutting off. DIY5
jamesw
on Feb 27, 2007 at 9:36:34 pm
The power shuts off before I can finish loading windows.Any ideas?
I have checked all of the power connectors and they seem fine.
TIA Jim
Evan Newsome
Re: Power keeps shutting off. DIY5
on Feb 27, 2007 at 10:01:32 pm
CPU overheating?
jamesw
on Feb 28, 2007 at 3:55:53 am
The fan on the cpu works.Do you think it might be a heat issue?
Evan Newsome
on Feb 28, 2007 at 2:32:30 pm
often when a heat sink is not well mounted on the CPU, the computer will shutdown before it over heats.
remove the hard drive and turn the computer on and let it sit for a several minutes, if it shuts down it is probably a heat sink issue.
some BIOS have a monitor of temperature, so you can look and see if it is rising to high.
jamesw
on Feb 28, 2007 at 5:42:27 pm
I reinstalled the fan and bingo everything is working.I owe you a beer
Evan Newsome
on Mar 1, 2007 at 4:04:15 am
glad it was an easy, cheap fix.
michelob light
