ASUS P5W DH Deluxe and RAID0 problem
Gary
by
on Feb 23, 2007 at 2:06:34 am
I have tried every combination I can think of and followed the Mobo user guide as best I could. Still, when I create a RAID0 in the Intel Matrix with an additional boot drive in SATA1 the system will not boot to WinXP. It gets as far as the login screen and automatically reboots. I have tried talking with ASUS and they act as if I am an idiot. I have always had good service from ASUS tech support but this time around they are downright testy with me.
Anyway, so far, the only way I can get my system to boot is to set the BIOS to standard IDE. If I set it to RAID it will not boot, either asking me to reboot and select proper boot device or rebooting on its own.
There is also a brief display saying that say "Detect Drives Done--No any drives detected" {sic} that appears during post whether the drives are listed in the BIOS or not, and even when system boots in standard IDE.
I have tried the EZ-RAID connetors with similar results.
I would really appreciate some direction at this point. Be happy to give you more info. But this should get the discussion going. Thanks.
Gary
Evan Newsome
Re: ASUS P5W DH Deluxe and RAID0 problem
on Feb 27, 2007 at 1:34:06 am
sounds like a setting in BIOS. go through ALL the settings and make sure they are correct.
