Built new system for <$1000.
vlro
by
on Dec 31, 2006 at 8:45:33 pm
Help, everything is installed and ready to go. The Bios recognizes the hard drives but when I try to load Windows, the hard drives cannot be found. help!!!!!
Jon Oransky
Re: Built new system for <$1000.
on Jan 2, 2007 at 7:31:22 pm
what kind of drives? SATA? IDE?
- Jon
vlro
Builting a system for <1000
by
on Jan 2, 2007 at 11:01:02 pm
SATA
vlro
Building a new system for <1000
by
on Jan 2, 2007 at 11:03:20 pm
By the way, Jon, I tried to call and talk to you today, but the lady said I had to be a customer to talk to anyone. I told her that was insane. We are going crazy here and just wanted to talk to someone.
Jon Oransky
on Jan 3, 2007 at 7:09:45 pm
did you connect the drives to the SATA RAID controller instead of the normal SATA? we don't offer phone support for building computers, but if you email me directly or post on here i'll try to help you out.
- Jon
vlro
by
on Jan 3, 2007 at 9:42:29 pm
Thanks so much, we will be getting back to you.
vlro
by
on Jan 3, 2007 at 11:07:18 pm
Tried both ways, neither worked.
vlro
by
on Jan 3, 2007 at 11:08:08 pm
Is this a common problem with this kind of setup?
Evan Newsome
on Jan 4, 2007 at 2:33:53 am
Disconnect all non-OS hard drives. and see if your OS drive will boot.
what MOBO do you have?
did you tell the BIOS which drive you wanted to be boot?
What did you setup as the boot order of devices?
vlro
Building new system for >1000
by
on Jan 12, 2007 at 4:08:18 am
Well after talking ASUS, they have determined that it is either the motherboard or the processor. How can you test them?
Evan Newsome
on Jan 12, 2007 at 4:27:45 pm
your post lack enough info to help you
sounds like a bios setting(s). (if your bios sees the HDDs... look at the little settings & make sure they are what you want them to be.... your owner's manual should tell you which each means)
