Video card for Core 2 Duo
JD8360
on Dec 18, 2006 at 3:19:42 pm
I am going to build a system along the lines of your DIY5 Core 2 Duo build because at its foundation is the latest technology. However I am confused about video cards. I have read the video card article but to me it is geared for the higher end editors. I am going to start with Premiere Elements or maybe Pinnacle Studio. I want to keep the cost of the system down where I can and spending $300 on a video card that is probably over kill is not what I want to do. Can anyone suggest a card that will meet the requirements of the lower end editors?
Evan Newsome
Re: Video card for Core 2 Duo
on Dec 19, 2006 at 1:54:50 am
Pick any card with 128-256MB that support Open GL and DirectX 9.
Premiere Elements does not use the video card for much more than displaying.
I think Pinnacle Studio uses the the processor on the graphic card to render real time effects.. so you may need a better card for pinnacle.
In short any modern ATI or NVidea card should work fine.
$100-150 card should be fine like a Radeon X800.
I suggest spend enough money to purchase a modern card that will work with Vista, have dual DVI out, will do higher resolution on DVI out, like 1920x1200. (in a few years the standard size LCD will be 22"wide or 24" wide.)
GrimReaper
What video card to replace the ATI Radeon X1900XX 512MB
on Dec 20, 2006 at 12:06:07 am
I am planning to use the same guide to build a new system and find that the ATI Radeon X1900XX 512MB are hard to find. I am probably going to run Studio, but may at some point use Liquid.
What video card would you suggest?
Evan Newsome
on Dec 20, 2006 at 3:19:03 am
Videoguy has an article on what cards to use with what NLE programs.
http://www.videoguys.com/DIY-GPU.html
FYI some stores like CompUSA have open box specials. I just saw a nice card from ATI for under $120.
