Final Cut Pro - quicktime conversion problem
saucehog
on Nov 29, 2006 at 4:29:40 pm
I'm haveing a problems with exporting using quicktime conversion in final cut pro. Up until this week I havent had any trouble with it AT ALL.
I'm working with HDV 1080i60 footage (1440X1080)
the videos will export, but the audio isn't synced up at all no matter what codec I use. I mostly use either the animation codec or the H.264. I've tried a few others but I still get the same results. I've double checked the frame rate and I still can't figure out why this stopped working correctly all the sudden.
If anyone has a clue what the problem is I would greatly appreciate it.
thanks.
