convert video file to 3GP
Owen06
on Nov 8, 2006 at 2:46:02 pm
AS 3G’coming,many new technology has been used in our everyday lift, 3G phone is one of the most important applications which has been newly adopted in 3G’s strom.Here I’d like to introduce a free software and tells us how to use it to convert video file to 3GP and play it in the mobile phone. Hope that will be helpful to you!
Modern mobile phones have more and more features. They include cameras, games, mp3 players, radio receivers and of course, video players. However the files you already have in your computer are not playable in your mobile phone right away.
To help you achieve that this guide exists! Of course, there are many 3GP converters,such as Imtoo 3GP video converter and 5Star Mobile video,which is easy to use . it supports comprehensive video and audio files including AVI, MPEG, 3GP,etc. With variable settings and fast converting speed, it is an affordable, high quality 3GP video encoder. But this time I will use the freeware tool SUPER, probably the best free video converter available. You can download it from the web site.
Lets explain all the settings you need one by one.
First of all you need to select the format of the video.
The great majority of the phones uses the 3gp format. Select "3gp (Nokia/NEC/Siemens)" here or the "3gp (Sony Ericsson)" if you have that brand. If your phone's brand is not here but you are positive you can playback videos, select the "3gp (Nokia/NEC/Siemens) " option. In the "Output Video Codec" field select H.263 and in the "Output Audio Codec" one of the AMR options .
What follows are the video settings . Here you must know your phone's resolution and select the setting closer to its native one. After you decide what resolution to use, set the aspect ratio and set the frame rate to 12.5 or 15. The bigger the better, but if you see what your phone has trouble playing back the files you made try lower values. Finally set the bitrate somewhere between 128 and 240.
Then you can put the videos you want to be converted. You can drag-and-drop them inside or right-click and select "Add Multimedia Files".
Before you click the Encode button lets review the settings in SUPER's menu.
A setting you should set before you encode is "Specify The Output Folder Destination", and select the directory in your hard disk that you want SUPER to put the files it will encode in.
Finally you are ready to encode! Click the encode button and after a while you will have a file perfectly playable in your mobile phone!
Afterwards just move it over to your phone and enjoy!
badboy
Re: convert video file to 3GP
on Nov 14, 2006 at 7:26:28 am
I know another 3gp converter,that is winavi [url=http://www.winavi.com/3gp%20video%20converter.htm]3gp converter.
BLANCHEAPRIL
on Nov 20, 2006 at 11:40:26 am
The good mixer to all audio files?
http://www.cdaudioconverter.com/audio-mixer/
Easy MP3 Audio Mixer is an easy to use but powerful program for mixing mp3, audio files, you can record your mixed music to mp3 directly. support mp3, ogg, wav file format.
CD Converter, Audio Converter, Audio mixer, radio, cd audio
Flying
on Dec 13, 2006 at 6:02:15 pm
http://www.movietaxi-3gp.info/ Their converter is cool that's for sure Wink
Check the supported formats:
Tivo to 3GP mobile phone
AVI to 3GP mobile phone
DivX to 3GP mobile phone
XviD to 3GP mobile phone
WMV to 3GP mobile phone
MPG to 3GP mobile phone
MPEG to 3GP mobile phone
SVCD to 3GP mobile phone
RM to 3GP mobile phone
RMVB to 3GP mobile phone
VOB to 3GP mobile phone
MOV to 3GP mobile phone
DAT to 3GP mobile phone
lostboys
HDV 3GP swf flv
on Dec 15, 2006 at 12:56:45 am
Acronym mania,
Hi! I am a Vegas 7 user with a FX1. I am currently captuinrg files with HDV Split, editing in Vegas 7, rendering to AVI and then converting to Flash via On2 Flix pro.
My goal is to create content for a website that will also have a cell phone version. I am using Flash for the standard website and am wondering what the standard is for cell phones? Is it H264, H263 etc ? What data rate is recommended? What should the aspect ratio setting be? Should I be cropping the 16 x 9 for the phones aspect ratio and also to get tighter shots?
What would be the fastest workflow for this situation?
Thank you!
seyes
on Dec 25, 2006 at 1:30:49 pm
i recommend you xilisoft ,it works well.Though it cost a little ,it is not expensive
forkart
on Jan 13, 2007 at 4:47:11 pm
I use yasa 3gp video converter to convert avi mpeg wmv to 3gp. you can read tutorial below.
How to convert AVI WMV ASF VOB to 3gp with YASA 3GP Video Converter
from http://www.yasasoft.com/tutorials/avito3gp.htm
1. Run [url=http://www.yasasoft.com/3gpvideoconverter/]YASA 3GP Video Converter
2. Choose "3GPP - 3rd Generation Partnership Project(*.3gp)" as Output Profiles.
3. Click "Add" button to select AVI video file.
4. Enter the output video file.
5. Select "Video" Page and set frame rate, frame size and Bitrate as you need. However we strongly recommend you to use default settings.
6. Select "Audio" page, set Audio Bitrate as you need. However we strongly recommend you to use default settings.
7. Click "Convert" button to start to convert AVI Video to 3GP.
chen22
on Jan 23, 2007 at 2:23:33 am
I use [url=http://www.qweas.com/download/video_dvd/video_converters/imtoo_3gp_video_converter.htm]ImTOO 3GP Video Converter to convert avi to 3gp. It works without any problem to me. It can convert other video files to 3GP, such as RM, MP4, MOV, WMV, MPEG, etc.
