Avid Problem no sound
jimboden
on Oct 26, 2006 at 4:11:18 pm
I have installed my recently purchased software with the mojo and have tried to edit some footage but I get no sound. I can see the bars moving on the time line to the sound but there is no sound coming from my speakers. I have made sure that sound comes from my computer but from avid I have nothing. What could be the problem? Avid is recognizing my sound card and is not complaining about not seeing any sound card.
Jim
jimboden
SOLVED
on Oct 27, 2006 at 2:21:22 pm
Found out with the mojo it sucks the sound to it. You have to either have a cable to connect the mojo speaker out to either a set of head phones or have it loop back into your line in of your computer.
Jim
Shanks
Re: SOLVED
on Oct 30, 2006 at 9:10:54 am
jimboden: Found out with the mojo it sucks the sound to it. You have to either have a cable to connect the mojo speaker out to either a set of head phones or have it loop back into your line in of your computer.
Jim
It seems not easy at first looking...
How did you find an decision of problem? Smile
jimboden
Re: Avid Problem no sound
on Oct 30, 2006 at 1:00:15 pm
I ended up calling avid to find that out. But I kinda figured that is what it was doing. I had a canopus card that you had to do the same thing to. Now when I edit video I put on a set of headphones that are attached to the mojo and it works just fine.
Jim
erica
on Oct 30, 2006 at 1:57:18 pm
sounds complex
