19" Widescreen Monitor for NLE?
ATLguy
on Oct 11, 2006 at 12:04:33 am
I'm thinking about buying a 19" Samsung Widescreen LCD Monitor - Model: 940BW. I currently have a 19" CRT, which works fine. I'll be using the PC I had built last year, using help from this site. (And it still rocks!) I've got Premiere Pro 1.5, a P5WD2 Premium mobo, a Pentium 4 640 3.2 GHz, and a PNY Quadro FX 540 w/Breakout Box. Any cons going with a widescreen, even though I won't be editing 16:9? The Samsung specs are 1440 x 900 resolution, 4 ms response time, 500:1 contrast ratio, dual inputs (Analog & DVI) and a brightness of 300 cdm. I think Premiere requires 1024 x 768 screen resolution. Your thoughts and info will be most helpful. Thanks...
ATLguy
Re: 19" Widescreen Monitor for NLE?
on Oct 13, 2006 at 3:30:53 pm
Further research indicates that I can't do what I wanted to do with a widescreen monitor, and should get a regular 19" or 20" model.
donphillipe
on Oct 16, 2006 at 5:54:10 pm
Can you share your research with us Smile THanks!!!!
Evan Newsome
on Dec 6, 2006 at 3:53:47 am
I have done a large amount of research on monitors.
a 19" Widescreen is too short.
I just ordered one 24" widescreen. (1920x1200) It should do the trick and I plan to no longer have two monitors.
I will report back my findings (after using it in the real world).
