Footage in Premier Pro glitchy Why?
Reggie Spires
on Oct 10, 2006 at 3:44:07 pm
Ok it is not stutering and it is not a hard drive issue. When I play the raw footage (Mpeg-2 file) in Windows Media Player it works fine... When I import it to Premier Pro it is glitchy ... any thoughts?
12quidkidinnit
Re: Footage in Premier Pro glitchy Why?
on Oct 28, 2006 at 1:34:54 am
rwspires: When I import it to Premier Pro it is glitchy ... any thoughts?
I think it's normal for it to do that at first. Have you tried rendering it after you import it. I've had this happen and rendering seemed to cure it. It's something to do with the different compression (or something).
gary_hendr
on Oct 28, 2006 at 3:33:08 pm
Well you can try using Combustion for this purpose. I experience the same problems with premiere, so I switched to combustion and the result was fine. Infact I felt much more at ease with it.
