Convert DVD to WMV with Pocket DVD Studio
dengfeng2010
on Aug 28, 2006 at 3:47:34 am
It's time to go mobile wild. Watch DVD movies on mobile devices ( Pocket PC , Smartphone , Palm ). Have fun when you are on the go. It's so convenient to put your favorite movies, TV show in your pocket and watch them anywhere at anytime.
This guide provides you an easy to use product that can convert DVDS to WMV format. Pocket DVD Studio allows you to select entire movie, or just one or several chapters to convert with adjustable bitrate, video size, Resolution, etc. In order to help us learn it quickly. I will give a simply introduction step by step.
First, download the product from its site and install it.
http://www.dvd-ripper-copy.com/pocket-dvd-studio.html
Second, import and edit DVD file
The program supports both DVD files and IFO file.
If you want to add DVD files, click the DVD icon and find the VIDEO_TS folder you want to add from your computer or your DVD disc, and then click OK to add the DVD files. Or you want to add an IFO file, you can just find the VIDEO_TS folder and selected the valid IFO file to add to the program.
All the chapters of the DVD are selected in the default setting. You can uncheck the box and choose you like. You will preview the video on the left box.
Third, set the output preferences
The program lets you add multiple projects to convert. You can set the output file name and output settings, and view the size and status of each project.
Click the name of a project and the program will let you change the file name.
Click Preferences to set the output settings of a project. See the figure below:
Output File Path: Click the browse button to specify a folder to save the converted file of the current project.
Audio: Select an audio channel and an audio frequency for the current project.
Video: Set the resolution, output format, frame rate, aspect ratio and bit rate for the current project.
Note: If you click “Default” button, all the original default settings will be restored.
Forth, converting
After completed the entire setting, click “convert” or “convert all” icon to convert what you want.
You can preview the current process of the conversion including its elapsed time and time remaining. Or check “Hide Preview” to don’t use it. After the conversion, you will find the converted files in the specified output folder.
Complete DVD to WMV converter with four steps, if you want to learn more detailed instruction,check out from its website:
Enjoy!
