DIY 4 memory configuration
Andy Martin
on Jun 9, 2006 at 7:20:27 pm
Recently built the DIY 4 machine with a few modifications (used a 950 dual core cpu and quadro fx1400 graphics card). The machine is working perfectly running Avid Express Pro.
Only slight concern is the fact that the BIOS reports that my memory is running at 533MHz when I know it should be 800MHz. I am using the original Videoguys specified Kingston KHX6400D2/1G (X2).
Anyone know how I can get the BIOS to recognise the full speed of this memory?
donphillipe
Re: DIY 4 memory configuration
on Oct 14, 2006 at 6:08:03 am
I was thinking of doing exactly the same ..... did you ever get your problem worked out (did you check the BIOS?) and how do you like this machine? What SW are you using and what type of work? Just curious - I am homevideophile using Adobe and going to upgrade to Sony HC3 camera soon (I hope!).
Dirttrack86
on Oct 16, 2006 at 3:07:57 pm
Hello, I am building the diy4. But can anyone tell me wich slots to put 2 sticks of 1gb ram in for dual channel? A1 and B1, or A1 and A2....... Please help, just a beginner. Thanks Very Happy
