XBox DVD compatibility format
djlender
on Jun 4, 2006 at 12:09:41 am
I am trying to burn home movies to DVD+RW's and they will play in regular DVD players and my computer but not in my original XBox. I am using Windows XP Home Edition and Nero Startsmart software. Is there a specific format that the DVD+RW has to be written in? The program settings are:
Video Mode: NTSC
Aspect Ratio: 4:3
Quality: Standard Play (5073 kbps)
Resolution: 720x480 (CCIR-601)
Thank you for any help you can give
Matt Gray
Re: XBox DVD compatibility format
on Jun 6, 2006 at 8:09:19 pm
Xbox will support DVD+R. I frequently use it to check on burned discs.
I know DVD-Rs won't play so it's likely that a DVD+RW might not be compatible either.
Or the DVD+RW is not being finalized? Just thinking out loud there.
