Capturing in AV
Dan0803
Capturing in AV
on May 31, 2006 at 3:35:09 pm
How does the quality of capturing camcorder footage in AV compare to that of capturing in DV?
I can not use firewire and USB, So pretty much the only way I can think of to satisfactorily capture is through an A V card for my computer and capture this way.
I'm a little confused however, the only thing I can think of is that this might be slower.. But surely the quality itself will be virtually the same since audio and visual is effectively streamed straight to the computer at the same quality as if I were to plug it into a television THEREFORE it will lose no quality whatsoever?
Any ideas?
