Music skips when playing back DVD that I mde
dsnyfans
on May 27, 2006 at 6:07:18 pm
Is there a really good program that sounds good when the movie is burned? I want to buy a really good program!
erica
Re: Music skips when playing back DVD that I mde
on Jul 1, 2006 at 5:06:56 pm
i'm using Xilisoft and quite satisfied with its quality, and the problem you have may relate to the audio rate issue, you should have a check of the setting you've made
Owen06
on Jul 2, 2006 at 11:46:28 pm
i thinks the problem you have is indeed what erica mentioned, it is not a matter of what soft you choose ,but the settings you made.so pls be patient.
