Avid long "indexing" on startup
COW Forums : Facilis Technology
Scott Davis
on Dec 4, 2012 at 12:15:54 am
It seems like everytime I launch Avid. It requires a long "indexing drive". We recently had a Terrablock installed. Is this normal?
Scott Davis
View Scott Davis's profile on LinkedIn
James McKenna
Re: Avid long "indexing" on startup
on Dec 4, 2012 at 2:54:55 pm
Hi Scott,
Did you recently move files from local storage to TerraBlock? If so, did you follow the procedure for creating new sub-directories for the Unity sharing workflow? You don't want to end up with all your files in the MXF/1 folder, that's not the way Avid wants to work in a shared environment. If you're not sure, please give us a call or email. Support - 978-562-7022 / support@facilis.com.
Jim McKenna
Matthew Mullen
on Dec 4, 2012 at 4:43:32 pm
Scott,
No this is not normal. Is it scanning the same folder every time? are you altering the contents of the media folder at all?
