Terrablock 6 user managmeant
COW Forums : Facilis Technology
Yonni Banin
on Jan 30, 2014 at 8:08:25 pm
Hey guys,
I Just got my 8xs 16tb Terrablock and im finding it hard to understand the user system.
I made a set of 3 users. One for my self as an admin, one for my assistant and one for our video editors
in our 4 room post production place. i find there is no way to disconnect a user, only to unmount and/or
sign in as another user. Anyhow the permissions wont change with the switch and i get write access to all
drives all the time.
Any ideas?
Matthew Mullen
Re: Terrablock 6 user managmeant
on Jan 30, 2014 at 8:39:29 pm
Yonni,
It sounds like you are leaving volumes mounted when switching users.
If you are going to use multiple users on the same machine you need to make sure you either unmount all the volumes before logging in with a different user or use the "Unmount all volume son exit" feature in the user mode menu.
Yonni Banin
on Jan 31, 2014 at 1:15:21 pm
Hey Matthew thanks for the fast respond.
The other issue is that when I'm unmounting the drives and then sign
in with the other user, this user gets read only on all drives.
Matthew Mullen
on Jan 31, 2014 at 3:20:15 pm
When you highlight the volume and look at the permissions pane, do you see the user having an R or a W next to it?
Yonni Banin
on Jan 31, 2014 at 8:15:52 pm
I see R.
Do you know about an issue with real time antivirus
protection and mounting volumes? Im using nod32
on all clients.
Matthew Mullen
on Jan 31, 2014 at 8:32:42 pm
An R means you have read access.
Real-time anti-virus can certainly cause mounting issues.
