Missing Drive after Power Failure
COW Forums : Facilis Technology
Ricky Barrow
on Oct 28, 2013 at 7:45:43 pm
Electricity went off hard, was restored about 15 minutes later. During the outage I unplugged TerraBlock. After power up, drive 20 was missing with 51 errors. Rebooted in Safe Mode and as it sequenced each of the 24 drives the blue "HDD" light blinked on every drive except #20 - rebooted again and 20 is still missing.
Can I assume the drive is gone and needs to be replaced or is there some utility to scan and repair?
Thanks! Ricky
Ricky
Matthew Mullen
Re: Missing Drive after Power Failure
on Oct 28, 2013 at 8:22:00 pm
You can try a re-seat of the drive. Shut the system down pull the drive out and seat it back in.
If it still does not come back up send the details of the failed drive to support@facilis.com
