Problem with Fibre Client
COW Forums : Facilis Technology
robert jax
on Mar 14, 2012 at 7:59:51 pm
We upgraded to client machine to 10.7 and now the Facilis drives wont mount on the desktop.
2006 Mac Pro
Fibre Atto FC-81EN
Config tool 3.38
Atto Driver - 2.0 (We've tried them all)
OSX 10.7.2
The Machine worked prior to our upgrade. Any ideas?
Rob Jax
Owner Fivesix Productions a Las Vegas video production company.
http://www.fivesixproductions.com
Greg Kessler
Re: Problem with Fibre Client
on Mar 14, 2012 at 8:28:26 pm
Hi Robert,
Are you having this problem with Single-User Write volumes,Multi-User Write, or a mixture of both? Also, do you see this problem on any other Macs or is it isolated to just this system?
-Greg
Facilis Support
robert jax
on Mar 15, 2012 at 8:42:29 am
The problem is just with this machine. I have other fibre and ethernet clients running no problem.
The Tools volume mounts to the desktop but the actual volume wont show up.
Rob Jax
Greg Kessler
on Mar 15, 2012 at 2:57:23 pm
Rob,
When you try to mount the volume in the TerraBlock Manager do you get a second copy of the Tools volume stuck on the desktop? Also, if you have Avid Media Composer installed, what is the version of Avid?
-Greg
Facilis Support
robert jax
on Mar 16, 2012 at 4:42:54 pm
The second tools does popup on the desktop. We do have Avid installed on the computer. I think it's 5.5.
Rob Jax
Greg Kessler
on Mar 16, 2012 at 4:53:14 pm
Rob,
Can you check the exact version of Media Composer? Multi-User Write volumes are not supported with Media Composer 5.5.3 for the exact reason you are seeing. If this is currently installed, upgrading to Avid Media Composer 6 should take care of the problem.
-Greg
Facilis Support
robert jax
on Mar 17, 2012 at 12:01:07 am
We are running 5.0.3. The drive comes up as an Ethernet client, It's just the fibre that is giving us problems.
Rob Jax
Greg Kessler
on Mar 17, 2012 at 12:15:36 am
Rob,
Version 5.0.3 of the TerraBlock or the Avid Media Composer. If TerraBlock 5.0.3, what version of Avid Media Composer is installed on that system?
-Greg
Facilis Support
robert jax
on Mar 19, 2012 at 4:07:01 pm
The client machine is running 5.0.3 on Avid and Terrablock Manager.
The Facilis Server Box is running 5.5.1.
Rob Jax
Greg Kessler
on Mar 19, 2012 at 4:17:55 pm
Rob,
If you've upgraded the server to 5.5.1 you need to be using the 5.5.1 Manager on the Mac as well. You can find the Mac Manager on the server in C:Program FilesFacilisTerraBlockManager.
-Greg
Facilis Support
robert jax
on Mar 19, 2012 at 6:16:41 pm
Hi Greg,
We have tried that. I just reinstalled it this morning to no avail.
The Drives immediately show as mounted but they don't appear on the desktop. The only thing that shows on the desktop are two Tools drives.
This is driving us crazy!
Rob Jax
Greg Kessler
on Mar 19, 2012 at 7:00:30 pm
Rob,
I'm not in the office myself today but if it's still not working with the 5.5 manager your best bet is to call in to our support line at 978-562-7022 and one of the other support guys should be able to help you out.
-Greg
Facilis Support
robert jax
on Mar 29, 2012 at 1:10:49 pm
So we found the culprit for this.
Our client machine is a macpro 2006 model. There is a conflict with the software because it's not a native 64 bit machine.
Everything ran smooth in Snow leopard but Lion is creating a problem.
FiveSix
Rob Jax
Dana Strom
on Oct 13, 2012 at 1:17:21 am
Having the same problems almost exactly as you describe, except on a 2007 model (MacPro2,1) which apparently isn't a native 64bit machine either....?
Is there a solution to this?
Chris Magid
on Oct 23, 2012 at 2:27:58 pm
What was the resolution to your issue?
We are having the same issue on a new iMac running MC v6 through a Atto Thunderbolt to Fiber adapter (supported).
Double tool volumes. Will not mount multi-writes to the desktop. TB Manager reports they are mounted. All sorts of flakey stuff.
We attempted to solve by trashing mount info on the server, client, delete users and etc. Server reboots, etc.
We have always found the management of multi-user write volumes to be challenging and problematic. Among other things. We have had similar issues on other machines and in many cases administering volumes and users require a server reboot. Not a pretty picture in a big shop.
Chris Magid
RTVF
Matthew Mullen
on Oct 23, 2012 at 8:55:52 pm
Chris,
We do support the ATTO thunderlink adapters but there is an NVRAM tweak that needs to be done.
I'm going to follow up with an e-mail to you on how to apply that.
-Matt
robert jax
on Oct 26, 2012 at 11:49:25 pm
The solution is to run as an ethernet client.
Wish we had a better answer.
Rob Jax
Matthew Mullen
on Oct 23, 2012 at 9:07:04 pm
Dana,
Do you have an e-mail so we can set up a time to talk about your issue?
You can e-mail me: matt@facilis.com
We can set up a time to talk.
-Matt
robert jax
on Oct 26, 2012 at 11:50:58 pm
Please post your solution so we can all see what will fix it.
Rob Jax
Matthew Mullen
on Oct 27, 2012 at 7:17:41 pm
Robert,
The fix is a new manager. If you e-mail me I can get it to you Monday. You need to be running Terrablock 5.6 to use the new manager.
Matt
