Adding transitions to split screen video causes black frame
Theodor Adam
on May 9, 2020 at 10:23:52 pm
Hey, I encountered a problem while adding transitions to split screen video. In this case I'm using slide transition. When I pick the slide push transition, one of the 2 videos in split screen drags behind it a black square or when I pick slide out, split screen videos diverge but again one videos drags behind it a black square which lasts about 1 more second after both videos go away.
Any tips? Thank you in advance
