Transcoding hours of MP4 ( H264 ) footage from gopro to be cut in FCP7 without ProRes?
Johnny Smith
on Jan 7, 2020 at 1:26:19 am
I got a few hours of gopro footage, a Mac Pro running 10.6.8 and FCP7. Rendering time for an hour of footage into ProRes 422 LT is 1 week +. Just brutal. Can't cut h264 footage as is FCP7 can't handle it. Is there an easier/faster solution?!
I also have a new macbook pro with Sierra 10.12.6 with Handbreak on it but no FCP or Compressor on that machine.
What's the best workflow for me?
Thank you thank you!
Doug Metz
Re: Transcoding hours of MP4 ( H264 ) footage from gopro to be cut in FCP7 without ProRes?
on Jan 7, 2020 at 11:04:40 pm
The MacBook Pro has a hardware decoder for H.264, so you'll definitely want to use the laptop... for this kind of transcoding, have a look at EditReady:
https://www.divergentmedia.com/editready
For the same money, you could also opt for Compressor.
Doug Metz
Dalton Agency
Johnny Smith
on Jan 9, 2020 at 6:22:52 am
It's not letting me buy Compressor on my Macbook Pro. ( I have an older compressor on Mac Pro that takes 8 hours to convert H264 to ProRes for every 8 min clip ).
Error: Compressor can’t be installed on “Macintosh HD” because macOS version 10.14.6 or later is required.
A screenshot of my Macbook is attached.
Doug Metz
on Jan 9, 2020 at 7:49:13 pm
I'm not sure how far you want to go, but upgrading to Mojave (10.14) would get you around that error, and you'd still retain 32-bit app functionality.
Alternatively, EditReady is definitely worth the money if you don't want to upgrade your OS just yet... but if you're willing to try something a bit more fiddly, you should also have a look at ff•Works: https://www.ffworks.net
Doug Metz
Dalton Agency
