Timecode Generator, wont sync up to my timeline!!
Brandon Lanski
on Dec 17, 2019 at 8:59:03 pm
Ok, so I'm kinda freaking out right now because I don't think I've run into this problem before but my timecode generator is skipping frames!
I need to send timecode and I was hoping the client could set markers in vimeo using the review tools and then it could just be a matter of typing in the timecode but . . . what am I doing wrong here?
Isn't that weird?
Jason Brown
Re: Timecode Generator, wont sync up to my timeline!!
on Dec 18, 2019 at 3:39:50 am
I don't know how to fix, but the colon vs semicolon is the most obvious difference. This usually indicates drop frame vs non-drop frame.
From my basic understanding, it means that the numbers change inconsistently in drop frame to match real time up with clock time. I believe it's 1 frame every minute except every 10 minutes when no frames are dropped...
First google search:
https://www.bhphotovideo.com/c/find/newsLetter/Frame-or-Non-Drop-Frame.jsp
Andreas Kiel
on Dec 18, 2019 at 2:18:22 pm
[Brandon Lanski] "Isn't that weird?"
No 😉
It just indicates you are using Drop Frame timecode in your project.
I'm not at a machine with FCP but I think in the effects inspector you can select a user TC instead of Source/Project, though this doesn't make sense.
You can switch to "Frames" - this will work with any timebase.
Spherico
http://www.spherico.com/filmtools
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
