Reverse order of clips?
Philip Nidler
on Dec 8, 2019 at 9:38:35 am
Hi!
I've put down about 20 clips into the timeline, however for some dumb reason I started from the bottom up so now the last clip is first. Is there any way to reverse the order in the timeline with a button or a simple click instead of dragging each and every clip into chronological order?
Thank you! :)
Doug Suiter
Re: Reverse order of clips?
on Dec 10, 2019 at 5:32:10 am
I was faced with this recently.
Not one button, but try this:
- Make sure "show used media ranges" is on
- select the event(s) in the browser where your media is
- click in the search bar, then click the icon next to it (it's called Toggle Filter HUD)
- Add the filter "Used"
- now with what's left, in column view arrange by content created / name / whatever else will set the in chronological order
- select all
- append edit (e)
DOUG SUITER: FCPTalent
Find Production and Post Production Talent, Free.
web: http://www.fcptalent.com
twitter: @FCPTalent
