Custom LUTs
Odille Grouillard
Custom LUTs
on Nov 30, 2019 at 10:27:51 pm
Hello,
I have a custom LUT from a shoot. Imported it, applied, and it looked great. For one of the cuts, I removed the LUT and exported it raw. Now I need to reapply the LUT and that doesn't seem to be an option. The clips with the working LUT two additional options in the Info Inspector:
1. Color Space Override (off is selected)
2. Camera LUT (custom LUT option selected)
The clips without the working LUT don't have this option.
Any help would be great.
O
Odille Grouillard
Re: Custom LUTs
on Dec 1, 2019 at 9:04:45 pm
Sorry for replying to my own thing, but I think I might not have been clear:
I simply want certain clips to regain the following options in Info Inspector:
Right now, they're simply not there.
Is there something obvious I'm missing? I just can't find the solution.
Any help would be great!
Odi
Brad Hurley
Re: Custom LUTs
on Dec 2, 2019 at 2:24:28 pm
I'm not sure how to re-enable that in the inspector, but there's another way to add a custom LUT, which is to go to the effects browser > color > Custom LUT, and drag that onto the clip(s).
One big advantage of this approach is that you can position the LUT after an initial color correction; you can even do this with camera LUTs. I rarely use LUTs, even technical/camera LUTs, but when I do I insert them this way.
Odille Grouillard
Re: Custom LUTs
on Dec 8, 2019 at 10:51:43 pm
That totally worked!
Thank you so much, Bruce!
