Chapter Markers?
Greg Ball
Chapter Markers?
on Nov 22, 2019 at 4:52:18 pm
Hi All
Happy Friday! I have a series of 25 90-minute videos edited in FCPX. The client is asking for DVDs to be authored. Each DVD will have about 20-30 chapters.
They've indicated where each chapter will be using time codes.
I'm having an outside author these DVDs. They use Encore for authoring. (They edit on Premier)
My question is If I add Chapter markers in FCPX and export ProRes 422 files, will these markers work within Encore? Is FCPX compatible with Encore?
Thanks.
Greg Ball, President
Ball Media Innovations, Inc.
https://www.ballmediainnovations.com
Eric Santiago
Re: Chapter Markers?
on Nov 22, 2019 at 4:57:28 pm
I do believe if you export a QT using Compressor with chapter markers intact, that will transfer over if imported into Premiere.
But that was years ago so of late I have no idea.
I can check in the next few hours.
Steve Connor
on Nov 22, 2019 at 6:36:41 pm
I never made it work in Encore but I might have been doing something wrong!
Mark Suszko
on Nov 22, 2019 at 8:53:07 pm
Would an XML file of the edit carry over the markers?
Eric Santiago
on Nov 22, 2019 at 9:03:50 pm
I found some time to test this with recent software.
From FCPX 10.4.3 to QT/FCPXML (used Xto7) then Premiere Pro CC2019, I can see the markers.
I then tried ProRes/MPG to Encore and nothing works.
I am not sure when they broke this but I was able to do this in the past.
Its been so long since I've done any media with Chapter Markers.
