GoPro Max 360 workflow
Alan Langdon
on Nov 14, 2019 at 8:55:01 pm
Hello.
Does anyone have a workflow they would like to share with GoPro Max's 360 footage (to keep it 360 and edit in FCPX)? It seems like the footage has to be converted in the GoPro app before importing into FCPX, is this true? If so, what are the options (in terms of quality and file-size... can you do a sort of proxy export from the app, use it in FCPX and then replace it with a ProRes 422 version?)
