Shortcut to replace *entire* clip with a PNG
Xavier Paredes
on Nov 1, 2019 at 4:50:29 pm
Is there a shortcut that would allow me to replace a selected clip in the timeline with another clip (a PNG in my case) BUT fill the whole span of it? This is what I currently have:
I simply want to replace the selected clip (i.e., what's within the yellow range) with a PNG.
The closest thing I was able to find is to hit "Q" but this adds the PNG above it. I want a shortcut to basically delete the exiting and replace it entirely.
Any help is appreciated.
Xavier
Eric Santiago
Re: Shortcut to replace *entire* clip with a PNG
on Nov 1, 2019 at 5:37:14 pm
D for Overwrite.
Xavier Paredes
on Nov 1, 2019 at 6:08:45 pm
...but when I hit "D" it overwrites the portion of the clip that's below it (2).
I need it to overwrite the selected clip (1).
Xavier
Eric Santiago
on Nov 1, 2019 at 7:21:04 pm
I was wondering why you asked to replace the entire clip but show us the range.
Eric Santiago
on Nov 1, 2019 at 7:24:02 pm
Should be Option + R.
Xavier Paredes
on Nov 1, 2019 at 7:37:31 pm
Sorry. Maybe my screenshots were misleading.
I tried "Option + R" but I got the "no can do" sound. But I figured it out!
If the clip is selected it will work. HOWEVER, if the clip is marked as a range (X on the keyboard) it won't work.
Just clarifying for those who might be looking for the same functionality.
Xavier
Jeremy Garchow
on Nov 4, 2019 at 10:07:15 pm
That's correct. Hit C and not X to select the clip, not the range of a clip.
