Importing from SD and it seems not...Hmmm
Ty Ford
on Oct 22, 2019 at 5:49:36 pm
My FCP X preferences are set to copy files. I imported an MXF file, did the edit, but .
Can't export I get can't be shared when referencing media on the camera (the SD card)
When I close FCP X, pull the SD card and reopen FCP X, I get media missing.
If I close FCP X , put the card back in and try to export it won't do it.
What user error am I achieving?
Thanks.
Ty Ford
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford's Blog
Jeremy Garchow
Re: Importing from SD and it seems not...Hmmm
on Oct 23, 2019 at 3:28:38 pm
try to reimport the media in to the current project using the File > Import > Reimport for Camera/Archive options.
Or open a new library and import that media again. Move that media over to your other library to reconnect it.
Ty Ford
on Oct 23, 2019 at 4:38:30 pm
Thanks Jeremy,
Why do you suppose the system failed to copy the media to disk as my preferences had set?
The file was 55 minutes. Maybe too long or it got interrupted?
Regards,
Ty Ford
Jeremy Garchow
on Oct 23, 2019 at 8:23:45 pm
Yes, it may have been interrupted, is my guess.
Joe Marler
on Oct 23, 2019 at 9:43:54 pm
[Ty Ford] "Why do you suppose the system failed to copy the media to disk as my preferences had set?
The file was 55 minutes. Maybe too long or it got interrupted?"
That is a possibility. In this video Ben Halsall illustrates how it can happen:
