What could it cost to upgrade iMac Pro Ram
Howie Young
on Oct 3, 2019 at 8:07:32 pm
Does anyone have an idea of how much it could cost for an authorized Apple repair service to upgrade the iMac Pro Ram from 32 GB to 64 GB after the initial configuration?
Bret Williams
Re: What could it cost to upgrade iMac Pro Ram
on Oct 6, 2019 at 3:05:17 am
I'm not sure about the iMac Pro, but he 27" iMac is super easy. Just pop open the little panel on the back and swap out the RAM for the new RAM at 1/4 what Apple charges. This is something you can do by yourself.
I would probably buy from OWC https://macsales.com as they have nice configurator to get you just the right RAM you need. For example you might have four slots with 2 16s already in 2 slots, so you could just add 16. But you might have 4 8s in 4 slots, so you'd have to lose all of the 8s to put in 4 16s.
But OWC should have the info on your model, and if not it should be pretty easy to figure out through the system info
______________________________________________________
https://BretFX.com FCPX Plugins & Tutorials
NEW PLUGIN - Text Message 2! ON SALE Through 10/7/19
https://bretfx.com/product/text-message/
NEW TUTORIAL - Animate Text in FCPX without Keyframes or Plugins
