Final Cut Pro frames per second view or display
Carlos Fraser
on Sep 15, 2019 at 4:22:34 pm
Hi guys..Does anyone here know or are familiar with Final Cut Pro enough to know if there is a setting i can check so that i can see in realtime during playback what the actual frames per second is? I know in Davinci Resolve u can see the playback fps in real time...Hoping fcpx has that same feature thanks...Would really appreciate it if anyone can point it out in fcpx thanks again
Jeff Kirkland
Re: Final Cut Pro frames per second view or display
on Sep 15, 2019 at 8:27:10 pm
There's nothing that I know of. FCPX can warn you if you're dropping frames on playback but that's about it.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Carlos Fraser
on Sep 15, 2019 at 8:29:18 pm
Ok thanks a lot for that information....
