How can I change the sample rate from 44.1khz to 48khz?
cybil lake
on May 14, 2019 at 2:32:37 pm
How can I change the sample rate from 44.1khz to 48khz on a single audio file?
Also where do I find the bit rate of an audio file - is it somewhere in the inspector?
thank you!
Helgi Thor
Re: How can I change the sample rate from 44.1khz to 48khz?
on May 14, 2019 at 6:21:10 pm
[cybil lake] "How can I change the sample rate from 44.1khz to 48khz on a single audio file?"
I don't think you can change the sample rate within Final Cut, you'll need to use an external application, like Compressor. There's also an online converter which should work:
https://online-audio-converter.com/
[cybil lake] "Also where do I find the bit rate of an audio file - is it somewhere in the inspector?"
Yes, it's shown in the upper right corner in the info tab of the inspector. You can also enable Audio Sample Rate column in the browser.
Helgi Thor
Editor
Fortaleza
Brazil
cybil lake
on May 14, 2019 at 7:33:03 pm
thank you - I will try that!
Tangier Clarke
on May 15, 2019 at 8:04:30 pm
Try Wave Agent. It's free.
