Burnedin subtitles with 'unlimited formatting options'...?
Christian Friis
on May 7, 2019 at 12:01:31 am
When working with captions in FCPX I often need to deliver videofiles with burnedin subtitles for clients. Each client have their own preference as to formatting, and to meet their expectations I sometimes have to do time-consuming workarounds... For instance today I've added a thousand 'tabs' to make the background fill the entire width of the screen, which couldn't be done in any other way with 'subtitle edit pro' which is one of the many tools i've tried. Has anyone come across a tool that provides 'unlimited formatting options' both to the text itself, but also to the background color, background fill area etc. ? Thanks.
Bouke Vahl
Re: Burnedin subtitles with 'unlimited formatting options'...?
on May 7, 2019 at 11:27:30 am
https://www.videotoolshed.com/product/subbits-subtitler/
The idea is that you do the titling outside your NLE, as that is faster, and you may want other outputs as well.
Watch this video for the looks. This is Premiere, but, it 'should' work the same in FCP:
And it comes with very good support, as (disclaimer), I'm the author.
Bouke
http://www.videotoolshed.com
Brett Sherman
on May 10, 2019 at 12:03:55 pm
Andreas Kiel who often posts here has a tool called X-Title Importer that converts SRT, ITT files into Titles.
http://www.spherico.com/filmtools/TitleExchange/XTI/index.html
You can make your own Title templates in Motion and use those for formatting.
Andreas Kiel
on May 12, 2019 at 4:46:20 pm
Brett, Thanks to mention my tools.
Another option is to convert already existend SCC, SRT, ITT captions to Motion Templates (user defined or with one of those which come along with the app) with another tool of mine.
Download here:
http://www.spherico.com/filmtools/TitleExchange/XTMojave/XTE-Mojave.dmg
TextUp Motion Templates download:
http://www.spherico.com/filmtools/TitleExchange/Plugins/TextUp_2018.dmg
TextUp usage:
http://www.spherico.com/filmtools/TitleExchange/XTMojave/TextUp_Usage.pdf
Spherico
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
