Library will not open after Final Cut Pro update
su jeong kang
on Mar 29, 2019 at 6:04:51 am
This time, I have Final Cut Pro X updated the version 10.4.6.
When I opened the library after the update,
I received a message that I should convert the png file into mov,
so I converted it.
Since then, the library won't open and it keeps turning off.
If I try to open a library from an old version of Final Cut, I can't open it because it's an updated library.
The backed up library also won't open because the library won't open.
It's a library I'm working on, so it's really important.
Is there any way?
I could try many ways
But same.
Please reply.
Thank you.
Ronny Courtens
Re: Library will not open after Final Cut Pro update
on Mar 30, 2019 at 6:02:30 pm
I have never seen FCP X ask me to convert a PNG file to a .mov video file when updating a Library, that even does not make sense.
To be clear:
1. You opened the Library, it asked you to update the Library to the newest version and then you got this strange message, is that correct?
2. You say you converted a PNG file to MOV. Where was that PNG file, and how did you convert it to MOV?
3. What did you do with the MOV file after the conversion?
- Ronny
su jeong kang
on Apr 1, 2019 at 4:26:57 am
Strangely enough, I got a message that I would convert 'png' into 'mov'.
I think it's because we didn't import the png file and we dragged it into the project.
After trying many ways to open library on the Internet, I saved the library.
It's not perfect, but it's not hard to work.
I don't think there are many, but I write down the methods I used for people with problems like myself.
1.I'm going to look at the hidden files in the library.
2.Delete the currentversion.flexible.
3.I opened it in the final cut X of the version before the update
->Although it damaged, I finally opened the library.
4.I opened the backed up library, exported it to the xml of each project.
5.I created a new library, and saved it.
Thank you Ronny for answering my question.
