how to rotate a clip with Ken Burns effect ?
cybil lake
on Mar 27, 2019 at 12:07:46 am
I rotated a clip using transform. Now, I want to use the ken burns effect to go move from left to right horizontally but the effect only seems to move vertically - as if I didn't rotate the clip initially.
Thanks for any help!
Jeff Kirkland
Re: how to rotate a clip with Ken Burns effect ?
on Mar 27, 2019 at 1:34:48 am
have you tried putting the rotated clip inside a compound clip and then applying the Ken Burns effect to the compound clip?
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
cybil lake
on Mar 27, 2019 at 8:54:02 pm
thank you - no I didn't try that.
is making a compound clip relatively easy?
thank u!
Greg Ball
on Mar 28, 2019 at 9:44:08 pm
Yes just right click on the combination of clips you want to use and select Compound clip from the options.
Simple
Greg Ball, President
Ball Media Innovations, Inc.
https://www.ballmediainnovations.com
cybil lake
on Mar 31, 2019 at 10:53:54 pm
thank you I will try that! ;)
cybil lake
on Apr 1, 2019 at 6:44:18 pm
thank you - it worked! ;-)
