How do you prepare your GoPro (upside down) content?
Tangier Clarke
on Mar 21, 2019 at 3:32:20 am
I am curious what tools you all use to process GoPro video that needs to be rotated 180 degrees.
Unfortunately, FCP X 10.4.5 will not allow rotating browser clips; only in the timeline. This is disappointing since I'd like to be able to play the clips right-side up and choose them from the browser rather than a storyline full of clips.
Compress has no option to rotate or flip the clips so I can't process them there.
GoPro Quick didn't seem to have batch processing, or at least I haven't found it yet.
I am about ready to go try DaVinci Resolve. Though whichever tool I use, one thing I do not want to happen is I don't want to lose any metadata and I want to maintain the original creation timestamp and timecode.
Your suggestions please.
Bouke Vahl
Re: How do you prepare your GoPro (upside down) content?
on Mar 21, 2019 at 9:20:32 am
Hi Tangier,
Did you try rotating in QT7?
This will change only the metadata for the rotation.
Not sure if FCPX will honor this though, but worth a test.
(If that works I can add it to QTchange.)
Bouke
http://www.videotoolshed.com
Jared Ewing
on Mar 21, 2019 at 7:36:12 pm
Hi Tangier,
I use the Finder Quick Actions. This video explains the steps:
- Jared
@FinalCutProHelp
Instagram.com/FinalCutProHelp
YouTube.com/FinalCutProHelp
Tangier Clarke
on Mar 21, 2019 at 10:44:40 pm
This helps Jared. Thanks.
Steve Connor
on Mar 23, 2019 at 7:15:39 pm
Surely you just select the clip, then select "open" in the clip menu, rotate it in the timeline then it's rotated in the browser as well?
That's what I do
Tangier Clarke
on Mar 23, 2019 at 7:19:40 pm
You know something - you're right and you taught me valuable lesson. I am so used to using key commands and/or double clicking a synced clip to reveal it's contents, I didn't think to use "open" in the clip menu. Additionally, it's not an option when right-clicking on clip.
However I was really looking for a way to batch do this, but thanks.
Steve Connor
on Mar 23, 2019 at 7:34:27 pm
I've assigned a key shortcut to "open clip" then it takes me no time at all to work my way through a batch of clips and "paste" effects to each clip.
Would be great if you could "paste effects" to clips in the browser though - perhaps submit a feature request?
