Converting multiple files with RAW to Log Conversion
Alex Koz
on Mar 18, 2019 at 2:21:01 pm
I need to convert multiple files with the option of "RAW to Log Conversion". As far as I know, FC Compressor doesn't have this feature. Is there any way I can batch convert footage (hundreds of files) in FCPX itself? Or maybe it's possible to switch RAW to Log Conversion in FC Compressor. Thanks for help!
Oliver Peters
Re: Converting multiple files with RAW to Log Conversion
on Mar 18, 2019 at 3:50:21 pm
Are these ProRes RAW files? If so, my suggestion is to follow these steps.
1) Import all clips into FCPX and place on one long timeline
2) Set the camera LUT for all clips to "none"
3) Use ClipExporter to export the timeline
http://www.clipexporter.com
ClipExporter will export the single timeline and then slice that single clip into individual clips. These will be converted to ProRes in the process.
EDIT - I'm not exactly sure if ClipExporter is still working or supported. I believe the developer is the one doing a similar function for FrameIO.
- Oliver
Oliver Peters - oliverpeters.com
Jeff Kirkland
on Mar 18, 2019 at 7:30:03 pm
If ClipExporter doesn't work, you can achieve the same thing using Marquis Broadcast's Worx4 X app.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Oliver Peters
on Mar 18, 2019 at 7:38:29 pm
Actually I just did a quick test. You can batch export straight from the browser if you have the free FrameIO extension. So, set the source clips to camera LUT = none. Select all the clips and use "share x clips" from the file menu. Pick the FrameIO Source preset. You will be asked to pick a codec and export location. Once done, you have the new files without needing to actually upload to FrameIO. These files will be at source resolution (with desired codec, like ProRes) at a log profile.
- Oliver
