When I export to XML, is FCP X adding to clip length??
Noam Osband
on Dec 4, 2018 at 11:14:45 pm
I've been editing podcasts using FCP X. I set them up in FCP X, and then I export to Logic for fine tuning and mixing.
It works great, but I've noticed sometimes when I export, it seems like FCP X is adding tails to the clips, so when I go through, there are some added "umms" or "uhhs" that I've taken out but are now in the session when I open it in Logic. Does FCP X do that? Can I change that?
Noam
Jeff Kirkland
Re: When I export to XML, is FCP X adding to clip length??
on Dec 9, 2018 at 8:15:49 pm
FCPX doesn't add any handles to your edits - I'd think it's more likely that Logic isn't interpreting the cuts as precisely as FCPX.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
