3840x2160 footage in a 3840x1634 timeline not fitting
Glenn Payne
on Nov 21, 2018 at 6:10:22 pm
Hey guys,
As the title says, I have 3840x2160 footage and I'm trying to make it 2:35 by making the project custom 3840x1634 resolution. That part went fine but when doing so the footage is placed into the super wide frame leaving vertical black bars on the left and right of the footage. Versus the full width of the footage fitting into the full width of the project frame. Is there some simple option I need to select somewhere? Some kind of "full frame" or "crop to fit" option I'm missing.
At present, I started the project file at 3840x2160 then manually changed it to 3840x1634 after a few clips were already in the timeline, if that matters.
Glenn
Glenn Payne
Re: 3840x2160 footage in a 3840x1634 timeline not fitting
on Nov 21, 2018 at 6:20:02 pm
I just found that you can highlight all clips in the timeline, go to "spacial conform" in the inspector settings and select "fill" from the dropdown box and it seems to make it fill the frame correctly. I'm wondering if that's the proper way to go about it without causing issues down the line.
Thanks for any input!
David Mathis
on Nov 22, 2018 at 1:06:19 am
You should be fine with that workflow. You can change the Spatial Conform of the clips before they are edited in the timeline. Just select the clips in the Browser and choose the setting you want.
Glenn Payne
on Nov 22, 2018 at 4:07:14 pm
Great! Thanks for confirming!
