Frame.io FCPX share destinations not installing?
James Culbertson
on Nov 21, 2018 at 2:49:31 am
Anyone else using Frame.io having issues getting the share destinations to show up?
I can install the Frame.io Mac app, and FCPX extension with no problem. But when installing the share destinations from the mac app account preferences, it says it is successfully installed but nothing show up under the share menu, and there is no Frame.io app under custom destinations. I've tried multiple times and also restarted the computers.
OSX 10.13.6, FCPX 10.4.4, 2013 MacPro
Jeremy Garchow
Re: Frame.io FCPX share destinations not installing?
on Nov 21, 2018 at 1:21:20 pm
What version of fcpx are you using?
James Culbertson
on Nov 21, 2018 at 7:47:29 pm
"FCPX 10.4.4" It does not work on older version.
Tech support is walking me through how to install the share destinations manually. So, looks like we are working it out.
Jonathan Dearth
on Nov 24, 2018 at 9:49:33 pm
An easy way is to just drag the missing files back into the clip list. It doesn't put them there twice. Then they are relinked.
James Culbertson
on Nov 25, 2018 at 2:20:09 am
[Jonathan Dearth] "An easy way is to just drag the missing files back into the clip list. It doesn't put them there twice. Then they are relinked."
I wasn't talking about video clips. I was talking about the Frame.io share destination presets for rendering. They told me how to manually create them, so its been worked out. Loving Frame.io functionality.
