Sound activated plugins for FCPX
Evan Brindle
on Nov 7, 2018 at 2:21:41 pm
Hi all,
I'm after a method to use the location sound (person talking) to effect the subtitles on screen.
Anyone got any plugins they can suggest?
Many Thanks
Mark Suszko
Re: Sound activated plugins for FCPX
on Nov 7, 2018 at 7:33:06 pm
In Motion, you can animate a behavior that's linked to an audio source, then publish that to FCPX. I made a plug-in that way once to blink the screen to black on the loud drum beats of an incoming music track, it was the fastest way to make a lot of 1 and 2 frame cuts when the dj "dropped the beat". Volume can also be used to keyframe changes in scale or other values, so a shout, for example, could drive the "wiggle" and scale effects to make a title seem to react or act in synch with someone shouting.
That the kind of thing you're looking for, or just a way to trigger titles to match in synch with dialogue?
Brett Sherman
on Nov 8, 2018 at 1:55:51 pm
How is what you want to do different than just normal subtitles?
