Imported clip get cut off?
Erick Puentes
on Nov 2, 2018 at 6:43:14 pm
I have a clip I imported and the last few seconds get cut off. I'm not sure what is going on. I tried reimporting but I get the same result. It will play just fine in QT so I'm not sure what the issue can be. Does anybody encounter this problem?
Specs of the file in question:
Eric Santiago
Re: Imported clip get cut off?
on Nov 3, 2018 at 3:31:44 pm
Can you use another app to convert to ProRes then import?
MPEG StreamClip or even VLC will do.
Assuming you dont have Compressor or AME.
