change duration not working?
Kyrina Bluerose
on Nov 2, 2018 at 9:13:24 am
selecting a clip
yellow selection box
ctrl+d
or right-click select change duration
not working. not even turning purple, won't accept numbers.
I can trim, and I can ctr+opt+r and enter number there but that takes longer...
any fixes?
Jeremy Garchow
Re: change duration not working?
on Nov 3, 2018 at 5:12:23 pm
How are you selecting the clip? Use ā€˜cā€™ and not ā€˜xā€™ to select a clip
Kyrina Bluerose
on Nov 3, 2018 at 8:56:59 pm
selecting clip in timeline - I usually just click on it.
it worked before I updated and now it doesn't.
Jeremy Garchow
on Nov 3, 2018 at 9:03:11 pm
First, see if you have some sort of custom keyboard preset selected (under Final Cut Pro > Commands menu).
Check to see if control-d is mapped to something else (or not mapped to Change Duration)
If that doesn't work, try trashing your preferences by quitting FCPX, and then hold command-option while you launch FCPX.
Kyrina Bluerose
on Nov 4, 2018 at 4:16:52 am
Brand new FCPX; not sure why it didn't work but that fixed it. Can't imagine how much more slowly the work would go without control d.
