copying animation moves to replacement still
Roger Sherman
on Nov 1, 2018 at 6:56:59 pm
i'm finishing a feature doc. Many of the stills we've used are low res and will be replaced by high res. Is there a way to copy the attributes of animation moves on stills and apply them to the replacement still? It will save tons of time, as you can imagine.
thanks,
Roger
Jeremy Garchow
Re: copying animation moves to replacement still
on Nov 1, 2018 at 8:47:32 pm
Copy (command-c)
Paste Attributes (Command-shift-v)
Or you could try reconnecting the still in the timeline to the new still, but depending on the raster size and spatial conform settings, this may get messy (as will copy and paste attributes).
Roger Sherman
on Nov 1, 2018 at 9:00:32 pm
thanks. I'll try it tomorrow.
Roger Sherman
on Nov 8, 2018 at 3:43:33 pm
It worked. What a time saver.
Many thanks!
