Can I keyframe the high pass and low pass filters?
Noam Osband
on Oct 9, 2018 at 6:55:15 pm
I am using the high pass and low pass filters. I want to adjust the DB level. I can move the one keyframe I see when I drop in the effect, but I can't add any keyframes. So I can't actually raise the DB level anywhere but that one point which ends up just making a spikey point. Any advice here? Can I add another keyframe in those filters?
Mark Suszko
Re: Can I keyframe the high pass and low pass filters?
on Oct 10, 2018 at 8:54:46 pm
I don't think high pass and low pass are necessarily the filters you want, if you're just wanting to smooth out the dynamic peaks and valleys. I used to use a freeware called "Levelator" to treat my audio externally, then drop it back into the timeline, but you get a similar effect in FCPX using the Limiter audio effect plug-in.
