Insert paste
Peter Spenceley
Insert paste
on Oct 9, 2018 at 10:09:50 am
I'm going crazy here. I'm trying to copy from a sequence and paste as an insert into another sequence. All I get is an overwrite on "tracks" above the clips following the place where I wanted to insert. Where am going wrong. Thanks for any advice. Peter
William Davis
Re: Insert paste
on Oct 9, 2018 at 1:09:27 pm
Hey Peter,
If the content you are copying from the original timeline is sitting above the storyline (connected clips) then it will also connect to the timeline you're pasting it into. You can paste and then drag it down into the storyline.
Cheers,
Bill
