Quickest way to fill a gap between two clips with video from the audio below them ?
Luke Will
on Sep 25, 2018 at 8:24:47 pm
What is the fastest and most efficient way to achieve the following with shortcuts:
On the timeline you have an audio clip with another separate video clip on top, and you cut a section out of the top cutaway so there’s a gap in the middle, and you want to fill this gap with the video associated with the audio clip below it?
Jeremy Garchow
Re: Quickest way to fill a gap between two clips with video from the audio below them ?
on Sep 26, 2018 at 11:46:10 am
Match frame from the in point of the audio (shift-f).
Select the gap in the timeline if it’s a gap clip, or mark the range if there’s no gap clip.
If there’s a gap clip, hit shift-2 to switch to video only mode and hit option-r to replace from start. This should replace the gap clip with the match framed video from the audio in your timeline.
If there’s no gap clip and you marked a range, hit “q” to add the video as a connected clip from the matched framed audio.
Afterwords, hit shift-1 to make sure you switch back to audio and video editing mode.
If this makes no sense to you, send a screengrab of the area of your timeline.
Luke Will
on Sep 26, 2018 at 12:49:35 pm
Wow thanks so much for the excellent work flow method. It makes complete sense. You are a gentleman !
