Automatic Audio Crossfade
Tony Wilson
on Aug 29, 2018 at 4:33:52 pm
My AppleScript App mimics keypresses in order to do an instant audio crossfade.
In FCPX Command editor:
Toggle Audio Fade In is SHIFT 9
Toggle Audio Fade Out is SHIFT 0
AppleScript:
try
do shell script "pgrep -x 'Final Cut Pro'"
on error
--FCP not open so quit
error number -128
end try
tell application "Final Cut Pro" to activate
tell application "System Events"
keystroke "[" using shift down
key code 47 using shift down
key code 126 --up
keystroke "]" using shift down
keystroke "," using shift down
key code 126 using command down --up
keystroke "0" using shift down
keystroke "s" using control down
key code 125 using command down --down
keystroke "9" using shift down
keystroke "a" using {command down, shift down}
end tell
The idea of a keyboard macro is not new, but this may be helpful.
Tony Wilson
12677_crossfade.app.zip
Chad Greene
Re: Automatic Audio Crossfade
on Aug 29, 2018 at 7:18:34 pm
Apple script is pretty cool. But just in case you are interested, check out this article on how to create an Audio Only transition using Motion. https://www.provideocoalition.com/audio-only-cross-fades-in-final-cut-pro-x...
Chad Greene : Mahoney Media : Minneapolis, Minnesota : 2x2.66 GHz 6-Core Intel Xeon, 12GB Ram, OS 10.11 FCPX, Kona-LHi
Tony Wilson
on Aug 29, 2018 at 9:07:26 pm
Hi Chad
I find the compound clips to be a pain to unpick with that method.
Tony
